hello after a while of car getting build i have ran in to a problem just before its back on the road and need help,
ok so if the car is running and u put wipers on the the car stalls, if u unplug the motor motor car wont start.
its a r33 with a r34 neo motor and a microtech if thats helps.....
Wat can i look for had a look and just cant nut it out
https://www.sau.com.au/forums/topic/356143-r33-help-please/
Hmmm, would it be possible to provide some photos of the wiring? Also perhaps it is best to continue trouble shooting with a tester and consult with a wiring diagram. And although it appears to be a very strange thing going on with your car, it doesn't appear to be a difficult problem, time consuming maybe. Good thing it is the weekend, more time to dive into the car.
https://www.sau.com.au/forums/topic/356143-r33-help-please/#findComment-5700395
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
