For Sale:
$10.900
Prestons NSW
Mitsubishi FTO GPX V6 MIVEC
This is a great example of a well kept and looked after vehicle.
This car has a excellent interior and exterior for its age, the car has traveled approx. 89 000km's without any problems.
This FTO GPX has a V6 MIVEC engine which enables great drivability in any situation with plenty of poke for the car lovers out there.
The car was regularly serviced and maintained as per manufacturers recommendations with premium motul oils and bosh platinum spark plugs.
This car has a full silicone intake duct with a high performance Saber air cleaner and chrome thermo resistant heat shield, the air cleaner is fire resistant and deemed to be road legal in that respect.
The full exhaust system was developed by Mitsubishi performance work shop MEEK, the full tune length extractors/headers with a 6:2:1 into a single high flow catelic converter which is further guided into a Lukey performance rear end with classic race finish chrome outlet. The engine mechanical tappet adjustment was checked by Mitsubishi rallyart performance mechanics at Mitsubishi service two years ago and were perfect with no adjustment needed, every FTO with [MIVEC v6] vale set up has to have this check once every 6 years or so to assure proper gap adjustment. The ecu on board computer on this car has been upgraded with a LINK performance ecu, which has done magic for this type of car. The aftermarket Rasin volt stabilizer system on this car has all electrical components protected and delivers a great voltage signal. The Link ECU allows adjustment of the air fuel ratio mixtures, this was installed and dyno tuned by leading performance workshop PULSE racing in Menai NSW. This car makes more power and torque than many Honda Type 'R' racing engines out there. The suspension system has been upgraded with race KYB shock absorbers and King springs for the desired ride height and handling, 17 inch Racing alloy wheels, this delivers excellent handling without compromising comfort, it just sticks to the road, it is not too low and climbs shopping speed humps without problems. The interior has been tastefully upgraded with the standard dash mount gauge pods upgraded with white faced air fuel ratio gauge and water temp gauge to keep the engine well monitored and also a carbon fibre gear-shifter, the very expensive Pioneer MP3 stereo system with MB Quart font speakers and splits also Sony explode 6 by 9 deliverers great sound. This car has full digital climate control and comfortable bucket seats. I only ever used BP98 premium fuel. This is a excellent car, i have owned it for several years and it still looks just as great as the day i bought it, i have invested a lot of money and time with performance upgrades and the new owner will be very happy with it, the car drives good and sounds great, with minor wear and tear as all cars of its age, i would consider this car in much better condition compared to many for sale out there.
https://www.sau.com.au/forums/topic/357268-mitsubishi-fto-gpx-mivec/
  • 5 weeks later...
How are people meant to find your car on carsales to view photos?
bump..!!
no pics, no link to pics
useless adds like this should just get deleted as they are pointless. nobody will buy this car without pictures
at 11k asking price, those pictures better be magical as well.
  • 2 months later...
Haha easy buddy..^
You are a bit of a tool saying that in someone elses post, if you have a recomendation then you can recomend it to me via PM you NOB..
The car is Magical.. it is a silver imaculate FTO .. no scratches or dints, but i will put pics up.. just to shut you up.. winge winge winge,,, hahahha
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
