Yo i wana buy a steerin wheel to play Live for Speed (http://www.liveforspeed.com)
Was wonderin which one you all recommend ? The 2 I was interested in are both logitech
1) Logitech Driving Force Pro with the 900 degree steering (couldnt find any of these for sale on ebay or anything)
2)Logitech Momo (the new one) which is like 165$ new off ebay
I wana get a cheap one like 2nd hand or somethin so any advice on any of these wheels would be great thanks!
:devfu: (soz just liek dis smiley)
https://www.sau.com.au/forums/topic/35728-pc-steering-wheel-help/
I've got the Logitech Momo one, and with Live for Speed, wheels are a b*tch to set-up. So far, I haven't been able to get it working, even with advice from the other players online.
Anyway, the Momo wheel is great; cost me $179 new at Harvey Norman. Tactile buttons, comfortable wheel, great pedals -- and the base is quite huge, with an anti-slip plate underneath, to stop it from sliding.
