1/4" -4 Sleeve (Per Foot) $9.00
3/8" -6 Sleeve (Per Foot) $11.00
1/2" -8 Sleeve (Per Foot) $12.00
5/8" -10 Sleeve (Per Foot) $14.00
3/4" -12 Sleeve (Per Foot) $16.00
1" -16 Sleeve (Per Foot) $19.00
1 1/4" -20 Sleeve (Per Foot) $23.00
I have 100 Foot of each size. Also i have the special heat proof sealing tape $5 a foot see pics.
Sometimes it can be tight to fit tube let me know what size you are going to run and i can check for you may just have to go up 1 tube size for you hose size.
Can pick up from Brisbane or Ipswich Just give me a call or msg Gus 0403467936.
https://www.sau.com.au/forums/topic/357749-heat-proof-tubing/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
