hks step 2 kit...
i was considering selling it and buying a nitto 3.2- but i just can't bring myself to put a forklift donk in my gtr! :no:
i'll put one in the stag though... :yes:
ok, so my plan is to get some 5mm longer allen head bolts, seal the plenum with grey max silicon as the rubber seal is to big, even after being in the freezer. I measured the runner length against std and the OEM manifold is about 5mm longer than the Greddy. I will get a thermal phenolic gasket which will make up the runner length and insulate at the same time. I just hope the plenum fits and the OEM studs are long enough.
Matt
Matt
Get a hold of a o-ring slice kit:
http://www.rshughes.com/products/079340_00112.html
And make your own... Or use the one you have and cut a little section out of it then re-join it.
In the splice kit is a tool to cut o-ring material perfectly square. Then with two very clean very straight edges you can bond them with fine (good quality) super glue or o-ring glue... I make orings for harder/harsher/higher temp applications than this use all the time and I've had no problems so far.
If you get a phenolic gasket cut in any decent thickness- cut me one too pleeeeeease???
Cheers
Justin
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
