as topic..
recently purchased half cut for engine only... R33 GTST series 1 Auto - KM's Travelled = 83205 km's
so i raped the half cut of the engine and now all bits left are for sale....
Also : forgot to mention
Climate Control :D - $150
Air Vents from top of the dash - sell sep or inc with Dash - $10
pic
Center Console (with the good 'ol auto button) - $30
pic
Dash-steering wheel and gear stick surrounding - $30 SOLD
pic
Whole dash unit inc air vents - $$$
pic
my dog - priceless :) SOLD - haha
pic
front left head light (the right one was smashed :) ) - $50
pic
Headlight damage - globes still ok
Glove box - $30
pic
Instrument cluster surrounding bit - $10
pic
Instrument cluster with 83 thou k's on the clock - $200
pic
RB25DET AFM inc plug if wanted - $ sold
pic
RB25DET auto gearbox with Automatic Ring Gear (inc xmember) - $600
pic
Ring Gear
R32GTST Engine Crossmember - $150
pic
R33 GTST STD ECU - $300
pic
STD air box - $20
pic
STD RB25DET cooler piping (leads to stock cooler) - $40
pic
other things i havnt got pics for yet (havnt cleared everything off the cut yet ) :
Stock front Suspension - exc con - $ 100
headlight wiring loom (from headlights to dash - $$$
Ignition key thingy with key (the thing u put ur key in to start car :) ) - $$$
Brake Booster - $60
R32 Gearbox crossmember - $80
Front indicators from front bumper - $60
no panels or bonnet
anything else i havnt thought of - throw your thoughts at me! :)
email: [email protected] for any queries
hey all - thanks for your interest
i forgot to mention that i'm not 100% keen on sending stuff over east - because i've never done it before and i'm afraid the pricks will damage shit in the process.
sorry if this is an inconvenience - or if anyone can change my mind otherwise
ok - i've decided i'm going to send stuff over east at Buyers cost of frieght  -  give me some time though because i work full time and find it hard to reach the Post Office in time
cheers
*BUMP*
WHat about the stuff i shotgun and requested from my PM? ill pay for the frieght as i said :D
thanks mate.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
