Yeah Pete from PLMS Developments told me that the V35 stock ECU is completely untuneable except for a Cobb system - and the USA Cobb distributors told me that the ECU wiring is subtley different between the G35 and V35, so would not work :( .... I will however get around to fitting my SAFCII one day so at least I can mess with the a/f ratios.
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760435
Trying to see if I can get a tuned ECU as a first step, Jetwreck speaks highly of Nismo ECU wih Emanage, would love to go the same. HKS is just too expensive and no tuners in SA :(
If you can find one, and you dont have to sell your kidney for it, it'd be a great step in the right direction. Rare as hens teeth though! Its a shame about the HKS, but thats fine; you'll hit the limitations of the gear box before you've maxed out the gains that you can get from the emanage.
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760461
Did no one in Japan do work on them? The 'big' tuning houses all worked out how to crack the M35 ECU and reprogram/remap to support appropriate mods.. but most of them want your car to do the tuning on OR charge through the roof for the services with only a very vague description of what the outcome will be.
My car had a high flowed turbo installed, and I dyno'd it at the last SAU:SA Dyno day with the stock ECU it had 125awkw.. a week later we ran it again with my Impul ECU and got 175awkw; but its a mixed bag if you go for anything other than an aftermarket Nismo ECU for us :(
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760466
Sadly because the V35 doesn't sport a snail, no Japanese houses took them on in terms of tuning, racing, styling or basically anything. Sure there are some Jap bits, but nearly every single thing I have bought for my V35 is out of the USA, where the tuning scene is huge.
Hell, even when they briefly ran some R/V35 cars in the JGTC they ran VQ30DETTs in them, rather than our beautiful VQ35s (the VQ30DETT was later replaced by the VK45DE) .... if only they had turbo's the V35 they would be an amazing thing .... pretty muh everyone that has done an aftermarket turbo or supercharger kit on them has cracked 300rwkw with relative ease.
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760487
If you can find one, and you dont have to sell your kidney for it, it'd be a great step in the right direction. Rare as hens teeth though! Its a shame about the HKS, but that's fine; you'll hit the limitations of the gear box before you've maxed out the gains that you can get from the emanage.
That's pretty much what I worked out, and I'm not after big power really. I'll try and get an ECU upgrade, maybe just a reflash even, then worry about a piggyback when the arguments in the Stagea section are finished and we have a winner :P
Why was the V35 so much bigger in the states than Japan? Seems odd...
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760695
Good plan :thumbsup:
Because it was sold as the Infinity G35 as opposed to the Nissan V35 :banana:
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760729
Yep, it was a combination of the Infiniti brand/badging, and the fact that they don't have R32/33/34 GTRs over there to overwhelm the V35/G35 (there are a handful of R32/33/34 private imports in the USA but even these have been deemeed to be illegal in recent times).
In Japan the V35 is considered slow, but in the USA a 3.5L V6 that can do sub-6 seconds 0-100km and high 13 second 1/4 mile is an attractive proposition - especially in a semi-luxury car with leather, sat-nav, Brembos etc etc.
https://www.sau.com.au/forums/topic/360181-tuners/page/2/#findComment-5760863
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
