hi guys...2 weeks ago i had a autobox in my cefiro and all run fine...now i got a rb20 manual in there and changed to a r32 ecu(thinking of buying a nistune chip^^)
the car runs really good, like always, idle is fine too when cold and warm...problem is if i drive down the road and try to stop i gotta clutch in lol
everytime i clutch in when downshifting or stopping the engine die >_<>_<>_<
sometimes the rev's drop to about 200-300rpms and then go up to the normal idle of about 600rpms but mostly when i kick the clutch in rev's drop just to zero and engine is dead!:glare:
the car is 100% stock, i got the aftermarked bov out, checked for leaks in the intercooler piping but nothing, idlevalve is cleaned too...
i'm going nuts, so pls community help me out :worship:
https://www.sau.com.au/forums/topic/360364-cefirorb20det-idle-problem/
Yeah manual is a bit different to auto...takes some getting used to :P
Does it do this after being on boost / off boost / both.
I'd say adjust the TPS unless it's boost related.
hmm i got no air/fuel gauge:(
and i got nothing to adjust too, i can buy nistune when the car is perfect^^...don't wanna buy now and then wait 2 months for money to get the car repaired >_<
lol it's not the first time i drive a manual,...thats not the problem^^
it's not just on boost, sometimes i drive 2000rpm and it dies...
i realize it dies everytime when i drive constant the same rpm a few minutes long and then stop...
btw with boost i got no issus,...it boosts great like always
nope no smoke,...but i think it could run a lil bit rich? maybe normal but i think it smells too much like gasoline out of the exhaust^^
gotta try to find a air/fuel gauge...btw does it has to be a expensive aem or does the cheap ones work too?
watertemp sensor is fine, the one for on the dash is find, but the another one for ecu i don't know how to check?
i love the way the emission fumes smell from Rb's really rich call me crazy lol
But the AEM's are good brand
Good Luck
I would say unless youre planning to go really into the drag and drifting the regular gauges will work fine
I have some regular gauges and they do the job ,been 2 years and no problems
They work well for my everday usage
As for yur problems as nic mentioned try another MAF and look into the mixture
Good Luck
i wanna really drift and use daily,...ok 200usd for these:(
but ok i won't need to buy these 5times a year:D
just ordered one @ aem
btw does it has to be a maf from a cefiro or a random r32 rb20det maf will be good too...
Not sure about the different MAF my advise is take the care where you would be buying it and try it to see if it works
I know some of the skyline MAF's work as they are skyline engines
As for the gauges youre good to go some years on that
If the AFM label is Purple and marked N60...it can be interchanged with Z32 300ZX [N/A only], J30 Maxima, or pretty much any Nissan with a VG30xx engine.
If its label is green, marked J60, it is interchangeable with R32 GTS-T RB20DET
If its not either of those colors let me know...but it should be one of the two, if it's not you got a problem.
i just borrow'd the maf from a friends friend and tested,...the same problem...>_<>_<>_<
now was thinking what i wouldn't need here and saw the cold start valve, here in thailand you won't get under 10degrees except you're on highest mountain here so got that piece of shit out and here we goooooo ideling alot better now :worship:
that f**king thing had a lil crack on it,...
i'm still waiting for the aem uego air/fuel gauge but i see a bit difference between the a31 auto ecu and the r32 manual ecu:
a31 stock ecu:
-idle is a tiny lil bit better
-but i waste a damn lot of gasoline!!! nearly 4 times more than the r32!:pwned:
donno but i think it's running hardcore rich to use that amount of gasoline...i had this one from beginning and car was drinking more fuel than i'm drinking beer in a month:D
-stock rpm gauge won't work with this one,...donno why?
r32:
-rpm gauge works surprisingly (i never touched the wireing!?)
-idle is a lil bit worser than the a31 but still driveable, not that bad...
-fuel economy is reasonable,...very good with that ecu...
from what i've read there shouldn't be a difference...abit confusing :closedeyes:
i had this problem.. give it some stick or even just drive through the gears. clutch it to roll to a stop and it would die.
Cas - advance it just a tad
Vacuum leak - check all lines
Throttle body. give it a good clean and make sure its adjusted properly
  • 2 years later...
I had the same problem on my car when I first got it, it is most likely a vacuum leak.
check and clean your IVAC and ACC also it should be a part of your maintenance anyway
And the simplest way to check for your leak is just to use carb cleaner and listen for a idle change to check for your leak.
Here is a video of what I mean: http://www.youtube.com/watch?v=9CPqbaSgcok
remember our cars are pretty old at this point so the hoses are just getting old so you might have the smallest crack in your lines so move them around to expose anything and check if they are getting hard.
This might help you out too : http://www.skylinesaustralia.com/forums/topic/174735-fixing-idlestarting-problems-rb25det-cleaning-air-regulator-easy-way/?hl=%2Bclean+%2Byour+%2Bacc
I have a 25 but search around if it is different on your 20
good luck and i hope everything works out!
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
