haha all good man, yer i thought i recognized the car. But yer ill definitely be there this year so ill pop over and check out the new package :).
(Also our cars would look sick next to each other both having the two tone)
so tbar crew cruise to power cruise like cool kids?
I know I am not a cool kid and if it won't make all the cool kids feel to lame I would be interested in tagging along and having a look
yeah I think that I should be able to make it as long as noone has a problem with my son coming olong he loved last year.
He has been asking when the next one is on all year round.
I have no problem with it
Chris/Tom anyone else wanna cruise down on the Saturday?
Yep I'll cruise down on the Saturday for a look
Vspec back in the shed after having a couple of nights sleepover with one of Noel's cars and another members car while we were at WTA. Was a great time and will be heading back next and a couple of you guys should come as well
  • 3 weeks later...
Let's hope they didn't wear protection....I want to be a foster parent to a little V-spec :)
Edited by tommis85
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
