Ok, question.
Anybody keen for something on Anzac day?
A cruise or a run and I'm happy.
Seriously been working too hard the past 3 weeks or so and I need my brothers to keep me sane.
Might have a friend in his car come too.
We can meet at the carpark as usual. Where's our fearless leader?
Ok, question.
Friend Reporting in. would be nice to join the Toowoomba crew for a drive anytime
Ok, question.
I maybe keen for a little drive, but won't know until tomorrow what I am doing on Thursday. Still need to put the mirrors back onto the car
Nick. Both Luke and Ben said they would be keen to come along. so thats a 350z and a v8 Kit car. You guys just set a time and place :)
This is for.... Thursday cruise (which I'm not sure is a thing) or happy laps?
No, Nick. This is me hoping for something to happen on Anzac day.
If nothing gets planned then I'll prolly still roam the streets somewhere with Garry. The twin silver brothers together again after a long separation LOL
Would like to go to Happy laps especially since they reduced the prices for "invited guests" of SAU QLD members ;)
However, the wife would want to come along but isn't in any state to be experiencing G Forces atm.
Member prices apply for guest of members who are passengers. If you wish to take your car out and aren't a member, you pay non-member rates. Otherwise we shall do to you what we did to nick...
LOL guess my interpretation was slightly off.
Sad its now much more expensive for non-members to join in with a great bunch of guys on the track :(
So nothing on for Thursday?
Is this because you guys are working Friday? :P
Hold up hold, what'd you do to me now?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
