I think we've stolen Brian from you guys. He comes to more of our meets then yours - probably because we have more meets. :P.
Chris, can you please liaise with Michelle and organise another Toowoomba meet. You guys did a great job last time so shall leave it up to you! Late June is probably best. Not the 29th though.
So are we really game for Sunday or what?
No details so far, no nothing... :(
Great leader will lead us from top of mountain to bottom of mountain back to top of mountain with supreme skill and leadership.
Sunday is a go. Really need to give the 32 a good run. Meet at the usual car park at 11:30 and we will go for a drive and lunch
Mkchelle hey? She sounds hot. Righto will do
LOL :P
Man that 180 sure gets around - the last week I must've spotted her like 3 or 4 times all over town lol ;)
Hmm I'm going out tonight sooo... May need to watch alcohol intake if I need to cruise over to the car park, or if you can pm/sext me where ur having lunch I can meet u there in the hatsu ;)
Not sure where we will be having lunch yet
I'm gunna have to bring the coonomodore the Gtr engine is all apart atm
Commodore is fine. Black is the new white ;)
You must turn up at car park. Your Great Leader demands this of all of us.
You dare disobey Great Leader?? :worship:
LOL :P
For real? She's spent all her time in the garage bar Anzac and the weekend.
Garry was in town with his silver one and there's another silver one in town somewhere too (but these two have quite distinct differences to mine).
Surely you must have the old girl confused with someone else :P
Ja rly ;) Well, I must be seeing things then :P I know that there was one other one...ah well ;)
in other news, the 33 has been made presentable....even took the wheels off for a scrub while inspecting brakes and suspension ;)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
