I gotta take the car to brissy on Tuesday cause nowhere in toowoomba will tune the ecu I got.
That is a very good idea - I wish I had never gone to anyone in town here either. Make sure to read up on the tuners first tho....there're some in Brisbane to steer well clear off too.
  • 3 weeks later...
Out of town this weekend... Seriously, I think Chris is planning these things to clash with my social calendar!
Would be keen for a catch up though, might have to put on a barbie one of these weekends. October is fairly ugly for me though...
21 standards challenge lol
Just don't try and be a "mini hulk" and try and lift me up and fail miserably and crash tackle us both into the bin again.
Xmas party will be happening again this year also.
8th of December, charity cruise?
Yup. Also organising Xmas party.
After 16 drinks I can't promise anything lol
