I know a certain person in this thread that has a few choices of turbos lying around ;)
He's a turbo whore and chops and changes whenever he sees fit.
Said person might even still have his ceramics if you just wanna do a swap.
Btw, inconel compressor + exhaust wheel FTW :P
Haha sure thing - you can try out my super-lag-spec R33 N1 turbos :)
All modern turbs have an iconel comp wheel :P :p Sorry Nick :P
Yep, good idea man...see if you can find a good set, but if not you're much better off going for a set of new (but equivalent) GT2860-7 turbos or their HKS GT-SS equivelant. If you don't mind a tiny bit of more lag go the 2860-9 ones like I did and you will never look back. They're good for around town, but when it comes to the QR straight they will put smile on your dial ;) They are pumping very hard where the ceramics simply run out of puff and rpms.
All day every day 290-320kw with them (on average)
A lot of -7 peeps make around the 280-310kw while the -9 guys will make around 300-330kw or so....bit of an overlap with these two turbos. They're very alike...the -9 is just trimmed up for an extra 30-50hp or so a bit more top end.
HKS is just a bit more expensive and comes with a higher rated actuator in most cases. The ones that come with the -9's will need at least 7mm of preload dialed on to them to make them work well - but I can give ya hand with that when the time comes. (Even with a EBC you will still need to wind on the preload or else the wastegates will open at like 6-8 pounds lol giving you a very lazy set of turbos!)
The -9's are definitely the new -7 if you know what I mean....most peeps I know regret having gone -7 after going in a car with -9's.
The -9's have the pull and lurch of a single turbo....whereas the -7's are often described as being very linear. Depends on what you like I guess.
All modern turbs have an iconel EXH wheel :P :P Sorry Nick :P
Fixed :ph34r:
Comp wheels are mostly aluminium or steel.
Forgot to mention, my turbo has the optional Titanium alloy exhaust wheel :P
Wouldn't you guys rather a more responsive turbo? So in this case the -7s would be ideal?
I always thought people went for linear power/greatest area under the curve so correct me if I'm wrong.
Laggier turbos move the power band higher up the rev range and by then the RB26 would be filling the catch can pretty quick.
Fixed :ph34r:
I'll argue this all day, I've never been a fan of "response" if I had a turbo it'd be the biggest laggiest power delivering piece of gear.
This is why I have a cam that makes no power until 3800 lol
Yeh you're right 180Nick, the more meat under the curve the better. Mine are -9's...you've been in it :)
Some peeps can make these come on almost as early as the stockers which I find quite amazing..
No comment Abomonick :P
...but if I ever have a 3L it will be getting the big single treatment :P
You only have 2?3? gears anyway lol
You stay in your powerband longer especially with that long arse auto diff pinion and crown ratio of yours.
Horses for courses
Response is where it's at for me - which also happens to be where I spend most of my driving 99.99% of the time.
Here's a link for Terry to make up his mind. Has both sides of the fence and no clear winner :D
http://www.skylinesaustralia.com/forums/topic/254450-79s-or-5s-garretts/
I have 4 gears with 1-3 being identical to a th400 and also have 3.6 diff gears, hardly moonshot spec! Thank you very much lol
But I also have a 3k stall so it's straight into powah! :devil:
Couldn't really feel any lag simply because I wasn't driving it nor was I looking at the tacho.
I think my comment after being in the driver's seat would differ though.
Having said that, it's a bit too scary for me. The sudden surge is brutal!
Oh that thread hehe...there're a couple of those in here. I think I have spammed all of them lolz :P
I spent a good 2-3 months just reading, reading and more reading - one of these threads is mine too. Worse still are the twin v single threads haha
...straight into wheel spin :P
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
