Was thinking about organizing to go bowling one Friday night then back to my place for a bbq and drinks. Also want to do a trip to brisbane to go karting
Definitely in.
Depending on my schedule for the week, I may have to miss bowling but I certainly can make food and drinks.
Unless of course it's this coming Friday where I know I'll finish early :P
Can't do karting. Would rather save that money for a Happy Laps or for those BBS wheels I want.
This guy, can't wait to hit up the new strip club with him, I'll be walking In With a roll of fives we'll be walking in with a bottle of royal purple lmao
Well if you walk in with a sack of coins they might get mad.
Hay guys figured intro myself seeing that ive pretty much moved here to your fine town in the sky"line" if ya see me around feel free the wave or honk i dont normally bite unless requested, i drive around in a 2 door black 34. Looking forward to getting to know some of ya's in the comming months.
Welcome mate. Keep an eye on this thread as nick said we do go for cruises from time to time. Am thinking of getting one organized for march.
Also the nandos meet is on this Saturday night if anyone is interested on going out for a look. I am ment to be doing a wedding on Saturday arvo but should be finished in time to head out
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
