Righto guys need some opinions on which way to go here with the 32. Am in the stages of starting to replace all the bushes, ball joints etc. I am planning on doing the suspension also and am torn between 2 options. Option 1 is to buy new suspension struts off nissan (if still available) and put them in the car. Option 2 is to get some nismo s tune coilovers and fit them and also get some standard struts of nissan to keep in the cupboard (once again if available) just to have so I still have standard suspension. What do you guys think I should do?
I would go option 3 which is to get some bilstein struts on stock springs and also get some standard nissan shocks to store in the cupboard.
I now understand why people rave about Bilstein's because the MRs came from the factory with them.
I do have some spare struts for the Caldina stored away for when the stock TRD (kyb) ones die. Won't need to get spares for the MR because Bilstein's last forever.
My research indicates that the Nismo S tune's are really good but can be a tiny bit harsh for our roads. Wouldn't want a mid-corner bump to unsettle the car now would we?
Who's doing the replacement of said bushes and the wheel alignment for you?
Umm im not from Toowoomba but I do live close by, I also have a friend with a v35 that lives close too so we may be interested in getting to know a few locals as such.
Black V35?
If so, it looks horn.
I really think it's time 'certain people' organised something for both the old heads and to welcome the multitude of new people that have popped up in this thread.
I'm new here myself so would love to tag along :yes:
Thanks Guys.
No the V35 is black, And it has a billet grille that is rare in this country. (check out my garage for a better pic) not to mention the awesome sounds I installed into it for him.
Myself and Nato (v35 owner) are doing a run from Dalby up to the sunny coast (Lunch by the beach) through the range next sat morning if anybody is interested.
Mooseboy
Don't think I can do a run up to the sunny coast just for lunch these days. Got plenty of things to do around the place. Have 'priorities' nowadays.
Stay single as long as you can and whatever you do, don't get kids until you're truly ready ;)
May be able to squeeze in something closer to home though.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
