hey guys, well time for a change so the car that has done me well for the past 3ish years is time to go. Been a great car, never had any problems with it.
2003
White
196,***kms
tow bar
tinted windows
aftermarket exhaust
17" Drift R's
previous owner put a pod filter on it too
Standard otherwise.
Bad:
Brake discs need machining, bit of vibrations under brakes, which i was going to get done on next service.
Rear tyres could use replacing
Headlight out and taillight out which i will try and get around to replacing before sale
Usual couple of small shopping trolley dents
Thats about it, reason for sale is i want to get a 4x4 for some off road fun so i will consider swaps for a suitable 4x4, otherwise looking for $9,900.
Pics show car with old wheels which were sold last year.
Cheers.
Will come with 3 months rego too.
https://www.sau.com.au/forums/topic/364637-sa-2003-ba-xt-falcon/
well took it today for a professional clean inside and out and she came up a treat, so car now comes nice and sparkly clean if purchased soon. Here is a couple of pics i just took.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
