Guys I have the following parts for sale, Parting out my r31, so all this shits gotta go.
S2 rb25det motor manual box and loom complete, with turbo and everything
specs:
Stock motor 120xxx k's Major service done 5k ago
Rebuilt and Hiflowed Turbo
Smooth as butter box no crunches, HD Clutch
Price: $2000 SOLD PENDING PAYMENT!!!
Front Mount Intercooler
specs:
600x300 suit r31 with rb25, side mounted pipes goes under headlight panel, very neat, all sprayed black comes with pipes
Price: $300
3" Exhaust Suit R31, Turbo back
Price: $300
MINEs ECU For suit R33 RB25det, better a/f maps
Price: $300
custom tail shaft R31 suit RB25 manual box
Price: $150
R31 silhouette lsd with mini spool 28 spline, 3.9 ratio.
Price: $150
BC racing s13 full adjustable coilovers F&R
specs:
BR Series, Spring rates are 8 & 6
Bought these brand new from justjap for $1300, Installed on car and lucky to have done 50k's, so basically brand new still.
Price: $1100
s13 front knuckles with brand new 5 Stud hubs, R33 GTST Calipers and Rotors
Price: $500 for complete setup.
s13 LCAs $50
hard race s14 tie rods and tie rod ends
specs:
Brand new in box, unused
Price: $180
18" Gmax Eagles staggered 9.5 rears and 8.5 fronts
specs:
Rims in GC, only a few minor marks on 2 of the lips
offset rears are +32 fronts are +35
really nice looking rim, Black with polished dish, nice dish on rear and perfect offset for nissans, originally came off r34 gtst and then my r31, come with tyres but they have seen better days.
Price: $1000
Custom Front bar S3 R31
specs:
has been primmered in hi fill 2k, ready to paint
Price: $250
Contact: Ph: 0435 521 442 or email hino83 at gmail.com or mark.hinson1 at defence.gov.au
best to get me on ph or email as i don't have access to ns.com during work hours.
Location: VIC, SE suburbs, can post interstate depending on parts.
More Pics to come hopefully on the W/E
  • 4 weeks later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
