My friend is currently selling his 1981 Delorean DMC-12. Attached is some info that he's typed up about it and posted on another forum...
I bought her back in 2007 and personally imported it from the US. She landed January 2009 and ever since I have been spending my spare time on her as a project car. A large amount of mechanical/restoration work was undertaken before she left the US. Once here, I continued the restoration myself and have spent many, many hours and $ getting her the way she is today.
The main features of this car are the gullwing doors and the stainless steel panels.
Some major jobs that have been done since I've acquired the car is the bumpers being repaired and re-sprayed and the dash & binnacle being re-wrapped (eliminating the cracks and making it look factory and brand new). I have installed a custom sound system which can easily be reversed. I'd made up a new backboard and mounted 6x9 Pioneers in the rear, with 4" Alpines in the front. Behind the driver's seat is an amp running a 10" sub (on a new piece, so again it can be removed and replaced with the original interior part still obtained) and is operated by a Pioneer head unit - all tastefully done in my opinion.
The car has been lowered from the factory height, giving it the true sports/exotic car look. Also, the wheels have been painted a lighter silver over the original grey finish, which makes them stand out more and always look great.
I take her out about once a month (would rather to more often) and she currently has 32,000miles on the clock. It has a 5sp manual transmission attached to the PRV-6 engine and although it doesn't have neck snapping performance, it's a true cruiser and turns every head along the way too.
To answer some questions before you ask...Yes, it does have a Flux Capacitor, but it doesn't come with the car and I have never hit 88mph in her, so I'm not sure if this one can go through time.
If you (or even someone you know) are looking for something different and unique, you can't go past a car like this.
Serious enquiries only please.
Asking price: $55,000
PH: 0418-557-357
*NOTE: This pic was taken before wheels were sprayed
https://www.sau.com.au/forums/topic/365470-fs-1981-delorean-dmc-12/
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
