hello everyone.
I am selling my, Mitsubishi Magna Sports 1999. semi manual sports gearbox. Five months registration.
I recently bought a r33 so iv'e decided to sell the Magna, originally i wanted to keep both,
but i live at home still, and don't have the room for both plus cant really afford two registrations.
This car handles like it is on rails, even in the wet. I have never had any problems with the car, Sounds real nice. great fun to drive threw the hinterland. surprisingly powerful engine, only sits 2100rpm doing 110kmh great on fuel roughly 5-6oo km, out of one tank using shell V power. I keep it in showroom condition, its the little things like going over the windows with razor blades that make it look sooo mint. This is for sure, a one off Magna.
When i bought this car every panel was kicked in by the guys angry missus, that's why he sold it cheap. tho he bought it for $22 000 when it was only a year old. i have the records and receipts from him. He had it fully went over, re-built the engine and put a new gearbox in a couple years before i got it. The odometer reads 290 000, but i think the cluster has been replaced too, it just way to hard to believe.
New recondition panels all from 2003 Magna Sports.
Bonnet$ 250
front bar $180
front fenders $150
new bonnet latch mechanism $50
rear bar $160
rear circle lights $200
boot and latch $200
spoiler $50
fog lights $200
grill $50
The roof has been chopped off and replaced with a roof from a Verada, with an electric dual function sun roof. $1750
Fresh respray custom champagne silver $2000
Near new B.L.V.D alba 20 inch wheel and thin white wall tyres, these come with my skyline but will put them with the sale. They fit just not really my thing to big. worth around $ 2500
Import clear headlights $300
K&N air fittler in stock cold air induction box $100
iridium spark plugs $ 120
sport leads $180
heavy duty battery, new connection leads $150
new brake pads $?
new radiator $200
new injectors $150
pioneer comp dome splits a few years old
keenwood 6x9 few years old
kicker sub 12"
kicker amp
Got some specs for a stock 99 sports off wiki:
4 Speaker Stereo
ABS (Antilock Brakes)
Adjustable Steering Col. - Tilt only
Air Conditioning
Alarm
Body Colour - Bumpers
Body Colour - Fittings
Body Colour - Grille
Central Locking - Remote/Keyless
Cruise Control
Disc Brakes Front Ventilated
Disc Brakes Rear Solid
Engine Immobiliser
Fog Lamps - Front
Headrests - Integrated 2nd Row
Intermittent Wipers - Variable
Leather Gear Knob
Leather Steering Wheel
Power Door Mirrors
Power Steering
Power Windows - Front & Rear
Radio Cassette
Remote Boot/Hatch Release
Remote Fuel Lid Release
Spoiler - Rear
Suspension - Sports
Tacho
Trip Computer (traction control) on/off
Kerb Weight (kg) 1457
Gross Combination Mass (kg) 3239
Gross Vehicle Mass (kg) 1889
Pay Load (kg) 432
Towing Braked (kg) 1500
Towing Not Braked (kg) 500
Wheel Base (mm) 2722
Length (mm) 4787
Width (mm) 1785
Height (mm) 1435
Track Front (mm) 1545
Track Rear (mm) 1535
Engine
Engine Location Front
Configuration V60
Engine Size (cc) 3497
Cam Overhead Cam
Engine Cycle 4 Stroke
Engine Type Piston
Engine Number 6G74M-######
Engine Code E35
Cylinders 6
Valves per Cylinder 4
Compression Ratio 9
Power 147kW @ 5000rpm
Torque 300Nm @ 4000-4000rpm
Acceleration 0-100Km/h (secs) 9.0
Induction System Aspirated
Fuel Type Petrol - Unleaded ULP
Fuel Tank Capacity (litres) 71
Fuel Delivery Multi-Point Injection
Method of Delivery Electronic Sequential
Fuel Urban (l/100km) 11.0
Fuel Extra Urban (l/100km) 7.0
Fuel Combined (l/100km) 8.5
$5500
If you have any questions please text me as I cannot answer my phone when I'm at work. and i will get back to you a.s.a.p
0406024937/ 0420710698 thanks. the car has 18" wheels on atm but will take them off and swap them for the 20s there is a pic of them still on my newy, uploaded two extra pics by accident and don't know how to remove them. Inspections welcome and recommended. cheers
Edited by n/a_neo_r33
I'll throw in the 18" that are on it as well, but two need repair. They're AMG tec art wheels.
Disregard the bit were its says two extra pics, that was only on boostcruzin, I just copy an pasted my add onto here.
and yes the 20 inch wheels on the skyline in that pic will be put on the Magna upon sale. sorry for any confusion
cheers
cheers
:domokun:
hey mate not sure if your taking the piss or not, but yeah just from autobarn nothing special, just wanted bigger pedals.
cheers
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
