Well i know normally when you have the handbreak in the centre it can be adjusted at the base of where the handle is to reduce the distance the lever travels till its at full lock. The issue i have is when i push the floor-hand brake on my auto to a normal sort of level if youre on an incline it doesnt do much, so its relying on the park gear to stop it rolling away. If however i push it overly firm and its virtually inline with the foot rest at this point then it is enough to stop it rolling. So i was wondering if anyone knows where the adjustment is located so that it doesnt need to be pressed in as far to engage fully? If anyone has seen a DIY on how to get to the adjustment point then a link would be much appreciated.
https://www.sau.com.au/forums/topic/366238-floor-handbrake-adjustment/
There is a DIY for this on www.g35driver.com, it is for a manual but it's virtually the same for the autos. Just that the adjuster that is normally beside the 'hand' brake is under the dash beside the 'foot' brake for autos. I did mine, took no time at all and now it works much better.
easily found the adjustment bolt at the top of the pedal... a couple turns and it was tight enough. I didnt bother doing the adjustment from behind the rear wheel as i got enough out of the one near the pedal. Was even easier than a normal hand break cause i didnt have to even remove any interior panels, was seriousley a 2min job... and that includes getting the tools out.
You can also actually adjust the park brakes shoes.. You may or may not know that v35 run a park brake setup where it has like drum brake setup which is in the inside o the rear rotors.. If u take your back wheels off u will see on the around the center of your rear rotor that there is a rubber grommets or plug.. Remove it then turn the rotor with park brake off.. Whilst turning get a torch and peep theru that hole u will see a sprocket looking mechanism.. Turning it will tighten or loosen your park brakes.. From memory it's located towards top of the rotor.. General rule is to tighten it to point where it locks up ad u can't turn the rotor and back off about 3 turns..
  • 1 year later...
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
