All parts located in Vic, CBD area - pickup preferred, will post some items at buyers expense.
Email [email protected]
Pics to come.
ATP 'frank' turbo, stainless manifold, t3 flange, will fit s14/15 SR20det, good for around 240-250rwkw with stock cams. Roughly equivalent size to GT30r. Braided lines included. $1300ono
Stack 8130 dash with sensors for oil temp, oil pressure, water temp, $1800 firm > cost over $2200 from vsport australia, excellent condition.
V8 supercar GT wing, 1.6m wide x 12" chord length, comes with mounts and allows adjustable angle of attack up to 20 degrees, painted black, red NISSAN sticker, excellent condition, $1000 for the lot. Will also include black R34 boot lid with pre-mounted reinforced crush tubes to mount the wing for free (will fit R34 GTR or R34 GT-T)
Racepace 3.5" rear muffler, super high flow but quiet $500
will throw in 3.5" cat-back mild steel piping to suit R34 if buyer wants it, i think the muffler can be used on r33 skyline too
used momo steering wheel, center horn button has been shaved around edges but will sit fine bolted to a boss kit, only have 5 out of 6 allen bolts (lost one) $100
used trust shift knob suit r34 skyline, 10mm thread (M10 x 1.25), will also fit s14 200sx, should suit other skylines, very good condition $40
used genuine nismo 1.3 bar radiator cap $20
2 x used genuine hks ssqv blow off valve flange adapters to suit skylines $20 each
r34 gtt triple guages, no housing $40
pair of s15 dmax vented front fenders +30mm brand new $280
Sorry for the delay.. PICS
also added s14 ganador mirrors, electric mirror control via factory loom, blue lens, very good condition. $330
correction the turbo is T2 flange
bit smaller than a gt30... i don't really know the specs it was on my car when i bought it. the induction pipe is included.
oh well, yeah i've had a fair bit of interest in the wing, but mostly interstate! even had a dude in Canada who wanted a shipping quote lol... Not really keen to send it interstate let alone overseas! I'm in no rush either way.
V8 wing in canada. That would be cool.
What model V8 supercar is it off? VY/VZ?
Hey mate spoke to the other day on the phone when you where at re autoworks havnt heard back still waiting to here from you about picking it up
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
