Rb20Det Standard Ecu
Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
I'm surprised to hear that, but then again, I haven't dealt with a low mount turbo in years. I'm presuming it's a space restriction issue. Cheers! -
Ah, that was not the answer I was hoping for. Is it only third gear that is the weak spot? Or do you have to change the whole gearset to make it hold some power?
You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
