Hks Turbo Timer
That's strange , I'm still on there but not much gets posted on there .
By patrickxdf12 · Posted
Thanks for the reply. Yes the fork is preloaded. I also want to ask there is only one way for the throw out bearing to go on right? The flat side should go towards the gearbox. I am using an 18mm clutch release bearing sleeve. -
try use your phone to record it? might be an issue with the shutter speed / refresh vs. the timing light, but worth a shot -
I’m here solo don’t have any hands to help so haven’t hit it with a timing light
When you crank your car, and hit it with a timing light, can you see a steady crank timing?
