Hey, guys
Just wondering what's the highest amount of k's you guys have had before doing a rebuild outta curiosity .. just waiting for the enviable
Im currently at 184'000 with just minor mods turbo back exhaust ,filter, fmic. And i don't track it just daily with abit of a squirt here and there with usual oil changes etc
Just wondering whats the most someone has got outta these engines with regular maintenance and minor mods etc
https://www.sau.com.au/forums/topic/367263-ks-on-rb25dett/
you should get plenty more kms out of the engine before it needs a rebuild. it really comes down to whether there is a physical failure or not. people have had to rebuild engines with well under 100,000kms on them because something let go, and others have gotten over 200,000kms on them and still going strong. if you want to find out what condition your motor is then get a compression test done as that is the only way to know how much life is left. no point asking for other peoples experiences because they don't really mean much in this sort of situation.
https://www.sau.com.au/forums/topic/367263-ks-on-rb25dett/#findComment-5858340
