Hey Guys,
I wanted to know if any of you would have for sale a R32 Original Steering wheel (for either GTS-T or GTR), or an R33 original series 1 wheel (the one without the air bag, and in the black material).
I currently have a standard R32 wheel in my car but it is getting really old (torn at the top and sides)and I would like to replace it with just a straight bolt on R32 wheel, or an R33 wheel (friend has told me he can make it fit)
I have attached two images, one of an R32 and one off an R33 series 1.
I am looking for a really good quality steering wheel (preferably in a great condition like the R33 pic I have added)
I'm currently in Wetherill Park NSW, but would travel to find a good condition wheel.
I hope to hear from you guys soon.
Regards
https://www.sau.com.au/forums/topic/368539-looking-for-r32-r32-series-1/
Hey, i have a stock r33 series 1 wheel but it has red trim on it, excellent condition, no rips or tears. Message me on 0431044680 if your interested and i can send you a pic. I have the gaiters to match that you can have for free if you want.
Hey Mate,
Thanks, I messaged you, my Email is [email protected], I am on most of the time.
That would be great if you have the gaitors too, How much for the wheel? and how much for postage?
Looking forward to seeing the pics, thanks
Hey All,
Still looking for an R32 or R33 (series 1) steering wheel in excellent condition,
Anyone has one, or know where I can get one please email me at [email protected]
Thanks
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
