1- "2x t28 turbos
1 rebuilt with new seals and braided lines. $400.
One is standard condition with hard lines and s14 manifold. 350.
Both with zero shaft play, no chips on fins"
2- selling my yokomo RC drift car, i just dont use it anymore..
had it for about 1.5 years but for 1 year of that it has been just sitting..
comes with:
yokomo top secret s15 package.
you get everything that comes with the pack when you buy it new (even box)
extras:
1 set of wheels with grip tyres
1 set of DISH wantanabe with drit tyres (new never used)
1 extra controller with reciever
1 bigger motor and control box with reciever
upgraded shocks (fitted to the car) stock comes with car
spare chassis with bits and pieces (almost complete, but in pieces)
tools
spare s15 chassis
spare ae86
spare r34 gtr (never used, no hose cut yet for posts)
3 batteries (big 3800, 1800, 1700?)
2x chargers
after $500ONO, this is easily a 1-1.2k package.
3- R32 gtr fibreglass rear wing, perfect condition. painted in ah3 maroon
$80ONO
4- r32 gtst bonnet and latch, perfect condition. in primer atm ready for paint, was ah3 maroon.
$140ONO
5- xtr turbo beanie.
used for 8 laps of mallala, doesnt fit between my trubo and strut tower :(
$80
pm me or 0433 290 801 for pics/info
cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
