Hey guys was just wondering if you could possibly give me a hand with an issue with my v spec diff.
i have just installed a v spec diff into a r33 gtst s2 replacing the factory alsd diff it came with.. i then had to get gtr hubs n shafts to suit diff.
put fluid in my boot by opening then nipple under pump and on top of diff and seemed all good. i noticed a couple days later i had no fluid, so i assumed it took it all to build up pressure. filled him up again and same thing happened, this time i looked under car and seen there was fluid dripping off the diff and for some reason from the car frame.
Also have used this vspec alsd diff with my old computer for my previous alsd diff which im not sure will lwork with it properly? but if not i have the v spec computer but am not sure if it is going to be compatible with my car?
basically i need to know if what i have done is going to cause something to leak or is there something i should check?
Cheers In ADvance!
https://www.sau.com.au/forums/topic/369433-v-spec-alsd-diff-leaking-fluid/
