1993 Skyline R33 GTS-T
122,000km. $12,500
Hey,
I've owned (and loved!) this car for the last 5 years.
After repainting the car in January, the turbo died. Ratherthan replacing the stock turbo, I had a much bigger one installed. Inhindsight, that was a bad idea, as I've now lost all my license points as thecar accelerates so easily. To ensure that I don't lose my license because Ineed it for work, I've bought a Hyundai excel.
SERVICING
The car has 122,000km's on it. I had a major service done at 100,000km's whichincluded a new heavy duty radiator, spitfire coilpacks, air con regassing, aswell as the usual timing belts, spark plugs, etc. I have it serviced every5,000km's by Gavin Wood AUTOTECH. Rebuilt and Re-shimmed diff.
INTERIOR
The interior looked a bit dated and old, so I've replaced everything I could tomake it more comfortable and modern looking. This includes a Series IIInstrument Cluster, Genuine R33 GTR Seats, Leather Steering Wheel, new leatherhand brake boot, gear boot and centre console cover, GTR gearknob, andcustom-made R33 floormats. If you have ever been in a normal GTS-T, you willsee and feel how much nicer this is.
The stereo consists of an Alpine head unit (iPOD and USBinput), and front and rear 6.5" splits running from a boot mounted amplifier.
EXTERIOR
Series I R33's aren't very attractive, so I performed a full Series II conversionincluding Series II headlights and grill, LED taillights, Trial front bodykit,and Series II rear spoiler. The car has 18" Wheels with Federal 595 Tyres. Thecar was originally dark gray, but was resprayed in Electric Orange in January,which has yellow in it when viewed in the sun. The car is lowered on TEINsuspension, with rolled front and rear guards.
ENGINE
All engine work has been done by Gavin Wood AUTOTECH.
Genuine Garrett GT3076 (0.82 exh housing) with 50mm External Wastegate.
PowerFC (Z32 AFM and 480cc Nissan S15 injectors)
Full 3" metal intake and exhaust. Front Mount Intercooler and Turbosmart BOV.
250kw with Dyno Sheets on conservative street tune.
PROBLEMS
All the usual R33 problems that happen at this age have been addressed. I'vehad the drivers power window relay fixed (R33 drivers power window often stopsworking after 15 years), air con buttons fixed (they occasionally break). Theclutch "friction point" is very close to the floor. I had the master and slavecylinder's rebuilt, which didn't help. My mechanic said it's not worth fixinguntil I am replacing the clutch, which I haven't done yet as it's still verygrippy.
I've owned this car for 5 years and really don't want to lether go, but it's either that or 1 more speeding fine causing a loss of license(and my job!).
Please, no test pilots!
Call or SMS Isaac anytime on 0421 517 163
My workplace has bad phone reception so between 8-4 I can be reached on (07)5573 8572
https://www.sau.com.au/forums/topic/369565-orange-r33-skyline/
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
