Hi guys,
Selling a few bits and pieces that I have lying around. All in working condition when removed.
1. Autogauge monster tacho - $25. Stripped from my RA28 a few years ago.
2. Autometer cobalt boost gauge - $40. Installed and worked on my Supra 12 months ago.
3. R-Spec Auto Turbo Timer ATT24X $20 - this came installed in my Stagea (current car) which was imported a couple of months. It does work, altho I scoured the internet looking for a manual but couldnt find anything. Turning on/off consisted of button mashing. :blink:
Contact PM or o4328o8254
1.
2.
3.
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/370274-tacho-boost-gauge-turbo-timer/
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
