One of the things of the original RB20/25 intake plenum is that the tubes are thin and long.
This apparently helps with low end power and torque.
The Greddy plenum has it's own runner tubes and they are big and short ie. making good high end power at the expense of low end.
One of the complaints of the various aftermarket plenums is that they bolt onto the OEM runner tubes.
Is this a good thing?
They make for neater IC piping and all the apparent benefits, a bigger plenum volume for high end and the OEM runners for low end.
Is this 'new thinking' right?
T.
https://www.sau.com.au/forums/topic/37037-plenums-and-runner-tube-length/
One important factor of intake runners is determining the velocity of the flow. Smaller diameter runners give high velocities, which fills the cylinders alot quicker. The problem is that at higher rpm and flow levels, the small diameter actually restricts flow and hurts top end.
Longer runners work on a similar principle, that the air speed is high and contributes to cylinder filling. The "ram" effect from the force of the high speed flow assists, and when design to work in conjuction with pulsing from the "echo" of the flow off the back of the closed/closing valve can fill a cylinder more efficiently than if it were an independant runner type manifold - similar to your old type Weber manifolds.
There are so many variables to calculate in designing an intake manifold that it's impossible to properly design one without alot of R & D. I think that the modified standard lower/ big plenum upper is a bit of hit and miss - it takes away some of the restriction in the long standard upper plenum but the shape and volume of the aftermarket bolt on plenum could be a bit... sub optimal. Of course it isn't going to be as good as a built-from-scratch manifold (like the Greddy), but then again it's price should reflect that (and only be around $500-700).
Price is not such a big deal really because whichever way it goes you're probably gonna take it up the arse in install charges, FMIC and all that jazz.
But the dyno charts of a Greddy intake sure is a sobering thought. I think a new plenum on the standard runners might be a good compromise but who's plenum to use?
T.
DoughBoy,
Can you please contact me on 0414-862-626.
Thanks,
Scott.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
