Hey guys, these are some FRONT coilovers to suit an S14 or S15. May fit S13 too but not sure.
Were going to make some custom strut tops and fit them to my x-trail but have changed my plans.
They have 8kg springs AFAIK.
Located in Perth, WA (northern Suburbs) Willing to post at buyers expense.
Asking $400, which is exactly what i bought them for 4 weeks ago.
Cam
https://www.sau.com.au/forums/topic/370445-fs-s14s15-front-coilovers/
