Hey i have to sell my r33, im heading to Port Hedland on Tuesday for work and will not be back for a while
its a 1993 model s1, 5 speed with 136000km, white
I just replaced the radius rod to chassis bushes and all other bushes fine
it has a 3" exhaust from turbo back, apexi pod filter, hks turbo timer, gfb atomic boost control set at 10 psi and has only been fitted for not even a month and i also changed the spark plugs at the same time
sparco wheels, also with another pair of 17" wheels, comes with standard air box and boost control lines, brass button clutch, greddy oil catch can
well looked after, i have only put 6000kms on it since i have owned it and has not missed a beat, done a few trips to sydney and has been great, i dont want to sell it but it is silly paying for rego and insurance if not driven
S2 seats
body is striaght apart from two little dints in passenger door and front bar has a crack in it, serviced and it has had a 100000km service as well with gates timing belt
runs out of rego on the 19th of this month but i can put rego on it for u if u like, $6000 no rego, $6900 with rego
Great car, only selling due to moving away for work, would love to keep it
0414269271 give me a call if you have any questions, located in Newcastle
Edited by hypo33
https://www.sau.com.au/forums/topic/371004-r33-gts-t-s1-136000kms/
will swap for a ktm250exc or ktm300exc 06 model and up
I have a Ktm 250 SFX. if u are interested ?
Its in good working condition needs a new cover for the air filter. can take photos and p.m if u like ?
Sorry mate im really after a road rego 2smoke
  • 4 weeks later...
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
