Hi I have up for sale is my toyota soarer, and below are some lists of what its got:
Electric Blue toyota soarer JZZ30 2.5L turbo
Rebuilt internal (still running in as i have only done approx. 200km since then)
car have just got a service 1 month ago with motul oil
18xxxxkm on the clock, well not really that km anymore due to engine has been rebuilt
Big single turbo conversion
Greddy/Trust TD06H-20G turbo
external wastegate
screamer pipe
oil catch return can
new NGK spark plugs
custom heat shield on turbo
K&N air intake with custom piping
"R154 5 speed manual conversion"!!!!!!!!
Microtech LTX-12s computer installed and tuned
Dyno tuned at 297.5hp @ wheels @ 14psi (Run in tune) as you can see the potential of this engine/turbo combination
Once its run-in with full tune, it should be able to do roughly 450hp@18~20psi with no problem.
*car was never boosted harder than 14, 15psi as I dont have a boost controller, it simply runs off the wastegate spring rate which is 14psi
18 inch Degeo slightly dished chrome wheels(in good condition)
2 new Nankang tires (in good nic)
wheel alignment and wheel balance done 1 week ago
twin 4 inch mufflers, 3 inch exhaust piping
custom front mount intercooler
custom body kit
rebuilt power steering pump
new electric window motor and assembly
custom blue/grey leather interior
custom DIY centre dash
JVC car mats
crystal look blue gear knob
Pioneer head-unit
turbo timer
Alpine ZR deep bass subwoofer
Alpine V12 amp
*things are removed from the car":(but do come with the sale)
GFB twin chamber blow off valve
Autogauge big shift light
Autogauge big monster tacho
HKS intercooler pipe piece
chrome gauge cup
rego til mid Oct
rwc upon deposit
Bads:
-few cracks and chips in the front spoiler and very minor crack in hood
-tear in under-bonnet lining
-synthetic blue leather insert in back seat damaged and foam underneath (due to left a leaking battery in the back seat)
*quoted around $200 redoing the damaged part on that seat*
-both seat belt buckles in the back needs replacing
-interior is in good condition but a few cracks wear and tear (common issue for soarer) here and there to be expected
in a 20 year old car.
-driver side head lights fallen a bit due to bolts broke off
-Dash LCD display works on and off, on and off, it works fine most of the time at night, but it seems lazy during the day
so, if you have always dreamed about having a big single turbo soarer in MANUAL, this is it! it wont disappoint!
Originally wanted $16,000 ( i know it might be a bit overpriced, well for the work that has been done on the car cost way more than
just $16,000, still) i have now dropped down to $11,000 to meet the market, so if you are in the market for a big hp manual soarer, please
do not hesitate to give me a call on 0433-350-626 or via TXT message if i cant take your calls due to i might be at work or even email at "[email protected]"
$11,000
thanks for your time reading!
Edited by sky_34
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
