  • Replies 114
Whats it like online? I havnt had time
pretty good, after playing lots of modern warfare ect it is pretty good not to get one shot killed all the f**king time! And when some one kills you you can opt to steal their loadout for the next life so even on low levels you get to try out lots of good weapon combos.
Dedicated servers is what they need.
lol not get one-shot killed? Haven't run into anyone with a Daemon Maul / Thunder Hammer?
They always seem to miss, or get a glancing blow, then they are screwed. Swords seem to be the way to go, you just keep hacking away and in no time the opponent is dead
What do dedicated servers do? Decrease lag?
Well dedicated servers would mean you could actually have a server on a decent connection like real PC games have. So instead of a 2-3-4-500 ping it could be 50 or less.
That would be nice, Most of the time my connection status bar is well and truly in the red, but the same goes for all games I play online so I am used to it now! lol
finished the game on normal on the weekend, not nearly long enough...
i also think it needed more space marines running around, the whole 1 or 3 marines defeating both ork and chaos armies was a bit .... unrealistic lol :rolleyes:
Think of it like 3 special characters fighting an army of standard orks, chaos marines and corrupted guards through a series of small scale engagements.
Then it is not quite so un-realistic.
Yeah its not like they were in straight up battles facing the whole Hoard or anything. It was mostly really small scale firefights where a Space Marine Captain and his Command Squad have everything going for them and could really cause some damage!
I found the Chaos Marines pretty hard to take down though, as soon as i saw a Marine i would immediately switch to my Lascannon, i wouldn't even bother with the Bolter.
In the board game, 2 shots from a Lascannon is more than enough to take down a Chaos Marine in Power Armour.
And try a round of close combat with a Space Marine captain loaded with wargear vs a group of 10 Slugga Boys, the Captain will win.
i mean unrealistic to the game. and by that 1 captain vs a hoard and a warboss or chaos son of rajab in termi gear, the captain would be smashed. but that wouldnt be a very fun game to play :rolleyes:
think i just would of liked to see more marines in it or something.
1 SM captain vs 10 slugga boyz would be to the orks me thinks.
edit. +1 to the Lascannon :thumbsup:
The captain could have been in Artificer Armour.
:edit:
Take a look at some of the feats performed by the main characters in other shooting games, people who are just normal human beings.
For the main character in Space Marine to achieve what he did does not require nearly as much bending of reality as most shooters (or movies for that matter).
Edited by Chappy
:edit:
So what you're saying is, Max Payne with the Kung-Fu mod wasn't realistic?
Why would you say that?
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
