My set of OEM NISSAN 370Z wheels made by ENKEI are now up for sale for $900 obo.
SIZE:
Front 225/50/18 x 8.0” wide Offset: +43
Rear 245/50/18 x 9.0” wide Offset: +15
Stud pattern = 5 x 114.3
These will definitely look the part on any Nissan (Skyline, Silvia, 200SX, 350z, 300zx, G35 etc) and will maintain a factory look, but give you a more agreesive stance and wider wheels with reduced weight over all older nissan stock rims!
Will fit over most sport brakes and big calipers too as they came standard on the 370z with sport brakes.
Sale is for wheels only... Wheel nuts are included though.
These rims are in perfect condition, had them on the car for only about 10,000km and they have NO chips or curb rashing.
Located in CARINDALE, BRISBANE QLD 4152. (Happy to help with shipping at buyers expense or local pickup/delivery).
Email me if your interested or for further pictures and details.
[email protected]
0412 879 829
Gianni
ps FYI, I am a long time member of the Z forums in Australia and US so can be trusted... dont post much on the Skyline forum however.
  • 1 month later...
BUMP!!
I still have these for sale now WITH TIRES - Yokahama Advan Sports (Stock tires) worth around $400 each brand new! 80% tread left!!
Asking $1,200 OBO
If interested message me.
0412 879 829
  • 5 weeks later...
BUMP!!
Asking $1,200 OBO
0412 879 829
BUMP!! Note this sale includes TIRES!!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
