Hey guys...
i've got an issue with my S2 R33 GTS-t...
managed to get a stuffed battery over the weekend so i went shopping and switched it out...
now that was no issue.. easy as pie and i'm pretty convinced she's running smoother than it has for a little while..
however, there is now a new issue that is a little concerning.. my airbag light in the dash is now blinking constantly..
i've tried searching the maintenance forums etc and haven't been able to find anything..
i was wondering if any one else has come across this issue and if they could tell me what needs to be done to rectify it..
just as a bit of further info, it wasn't flashing prior to the battery change.. and nothing got sparked or anything during the fitment of the new battery..
cheers guys...
https://www.sau.com.au/forums/topic/374804-blinking-srs-airbag-light-help/
well after some further research last night i found how to reset the airbags..
so now the annoying (and unsettling) blinking light is gone...
turns out that you have to turn the ignition on and press the drivers side interior light switch 7 times within 10 secs.. i found i had to do this twice and then it was gone..
thanks to you jimmy for your input as i'd forgotten to do that...
now to start dealing with all the other little things i need to get done..... lol.
changed out the battery....
i read in my further research that it is heard of happening when you disconnect the battery fully.. and mine was outta the car for about an hour by the time i pulled it apart, got the part number off it, and then walked to my nearest Auto Pro... fortunately for me i'm only about a 15 min walk to one...
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
