Does anyone know an easy way of sticking down the bubbles on the corner parts of your dash caused by the heat?
My SL has just started getting sun wrinkles.. The only way i see that you can get them down would be to get some glue into the bubbles.. The only way i can think of to do that would be to inject some glue with a syringe. If you do happen to do this, make sure you use a thermosetting glue (epoxy etc) and not a thermoplastic glue.. otherwise the glue will go all soft again when it gets hot.
A car upholsterer might have some ideas (mostly expensive ideas i'd say)
https://www.sau.com.au/forums/topic/37506-bubbles-in-dash/#findComment-753585
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
