Item: 1x Recaro EP3 - Red Suede/Sports Trim
Condition: Used, excellent condition.
Description: No burn marks, scratches or tears but just very dusty. Also has the pop out extension at the front. No seat rails included.
NOTE: Passenger side only as scroll is on the left hand side. Modifications may be made to convert to driver side.
Price: $850
Item: 2x Recaro Evo 7 - Black/Grey/Blue Sports Trim
Description: Immaculate. No burn marks, scratches, tears. Comes with Evo 7 seat rails.
NOTE: Matching rear seats can also be supplied also in excellent condition.
Price: $1850 [Not looking to separate]
Item: Steering Wheel
Description: No scratches or tears. Not too sure of brand but has a Nismo horn button.
Price: $50
Item: Momo Nissan OEM Steering Wheel
Condition: Used, in good condition.
Description: Tiny bit of wear and tear. Comes with complete airbag.
Price: $50
Item: Rays Gram Lights 57S - Gold, Multi-stud
Size & Offset: 17 x 8.5 +30
Tyres: Yokohama Advan 235/45/17 - 60% Tread
Condition: Used, Immaculate
Description: Very very minimal scratches if any, no centre caps.
Price: $1750
dsc08906v.th.jpg dsc08907m.th.jpg dsc08908f.th.jpg dsc08909i.th.jpg dsc08910f.th.jpg dsc08912a.th.jpg
Item: Work Emotions XT7 - White, Staggered sizes.
Size & Offset: 2x 18 x 8.5 +38, 2x 18 x 9.5 +38
Tyres: Yokohama S-Drive 235/40/18 90% Tread, 265/35/18 90% Tread
Condition: Uses, Immaculate
Description: Very very minimal scratches if any, comes with Work Emotion centre caps.
Price: $1850
dsc08914z.th.jpg dsc08915lh.th.jpg dsc08916i.th.jpg dsc08917f.th.jpg dsc08918.th.jpg
Item: 4x 30mm Wheel Spacers. YES 30mm SPACERS
Condition: Used, excellent working condition
Description: Comes with all lug nuts.
Price: $200
Item: 2x Apexi Pod Filters with adapters for GTR.
Condition: Used, good working condition.
Description: Comes with brackets, genuine Apexi adapters and filters.
Price: $130
All items will be sold as is. Pickup is preferred for bulky items and it can be arranged either in Sydney City or Castle Hill, NSW. If there are any questions please dont hesitate to ask via PM.
cheers,
Garland
https://www.sau.com.au/forums/topic/378007-nsw-brand-name-parts/
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
