My car - R33 gtst, series 1
On the power fc sensor check screen there is one called F/P which is described as fuel pump, another one called FP1 which is described as fuel pump control.
At idle the F/P is on and the FP1 is off.
When the throttle is pressed the FP1 switches on, back off and it switches off again.
I did find a possible/plausible explanation which goes a bit like this.
As a safety feature, when the car is started, the fuel pump is powered by the ecu. After a certain time, lets say five seconds, there is a relay that switches so that the fuel pump is being powered through the oil pressure sensor. The reason for this is so that in the event of an accident where the engine is mangled, the engine will stop, oil pressure drops to 0 and fuel pump switches off to prevent a fire from fuel pissing out everywhere.
Cant remember where i found that, but i know it was not on a nissan forum, so could be totally un-related to our cars, but it does seem plausible.
Can anyone explain if this is whats happening with this FP1 sensor switching on with throttle ie : fuel pump being powered by ecu, then when ya back off it switches to being powered by oil pressure sensor.
Or something similar
https://www.sau.com.au/forums/topic/378576-r33-fuel-pump-control-question/
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
