I have a white tommy kaira wing off my R33, it is in mint condition except for 2 small stress fractures from screws (almost unseeable). Will have pics up tommorow. Looking for around $350 email [email protected] or pm me
Cheers Matt
https://www.sau.com.au/forums/topic/37956-tommy-kaira-wing/
  • 1 month later...
