14inch thermo $30
Rb20det crossover pipe with blocked off bov $30
2x standard rb dump pipes$30 each
2x standard exhaust manifold heat shields $20each
2 standard turbo elbows rb25 det $20 each
Top half rb20 plenum $20
R32 hicas module $30
3x turbo heatsheilds standard rb $20 each
Rb exhaust manifolds standard cast $ 50 each x 3
R32 projector headlights not the best nick $100 pAir
R32 gtr intake plenum no butterfly's just plenum $100
Rb20det fuel rail $20
Rb20det injectors standard $50 set
Rb20det ecu $125
Rb25de ecu $125
Rb25det ecu $125
S13/180sx front lip ca original plastic $150
Rb20 intake plenum lower half $20
Bosch 040 fuel pump good nick $100
Rb20 det wastegate actuator $20
Air con bracket and pulley rb25 det $50
Rb25 de engine loom no injector half $50
Located in port macquarie nsw 2444
Contact Josh 0421 229 021
Thanks
https://www.sau.com.au/forums/topic/379815-random-crap/
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
