Hey Selling my much loved S15 Spec R
Very loved and looked after serviced every 8-10K with good oils and plugs, only ever run on prem unleaded
Only selling as i have a 4x4 work my work car and dont have space for a weekend car
its done almost 90,000kms
Mods
-Full Exforce Exhaust system (Dump pipe, front pipe, hi flow cat, cat back all 3")
-Hybrid Front Mount Intercooler
-GFB Blow off vavle (Adjustable Cost 700 alone comes with box)
-Momo 17" wheels
-Nismo Front Strut Brace
-Greddy Air Defuser
-Apexi Air Filter
-Blitz Turbo Timer
-GPS Sat nav/DVD/CD/MP3/Am/Fm/ so forth
-Boost gauge in the center Air Con Vent
-Hertz Speakers (Splits ip front and 2 ways in the back)
-Nismo Clear indicators
-Flashpoint Australian standards Alarms System With Auto window Close
-6K HIDs (bright and white)
Car still running stock boost as it was my dayly so kept it nice a simple / reliable its an ADM is no rust and cheap insurance thumb.gif
Any questions feel free to ask
chasing $17500
Edited by VicSlidin
https://www.sau.com.au/forums/topic/380083-s15-2001-spec-r/
