I just recently install a Profec A, and from the moment i turned it on, the control/soleniod unit made a heep of wierd 'computer' and clicking sounds. After everything was setup up, the unit still makes these noises when the car is turned off but the ignition is on. It seems to me like the soleniods are constantly opening and closing! Is this supposed to happen? All my vacume hoses are setup correctly, and the controller itself is working fine at controlling boost?
Another query, does anyone have the Profec A instruction manual (pdf or other electronic form?) my email is weq@mooh.org, id apprecaite it!
Thanks for ur help!
https://www.sau.com.au/forums/topic/38020-profec-a-any-ebc-query/
Weq - I know that alot of solenoids will make a bit of a sound when it initially turns on, but shouldnt keep making it. A mate had an almost new HKS EVC5 and the guy he bought it off didnt have the in line filters installed and had a lot of blow by oil inside.. Im pretty sure he had similar sounds too you and after a quick clean it stopped the sounds.
Re manual, i downloaded a manual from the net when I had my profec a (needed it to set it up properly). Do a search on google or try trust.com - there is a pdf manual around somewhere!
Thanks for ur help!
Noise is normal :) It even says it in the manual, so dont't worry about it
I have emailed you the instructions as well, make sure its set up properly and it should be fine
NOTE - with the learn procedure 'P1', keep doing full boost runs in 3rd and 2nd gears, do as many as possible, as it will make the boost curve more stable, then P2 mode, use 3rd gear
I have found this works the best
Chris
Seriously guys, really apprecaite the info! I was a bit confused with the P1 and P2 learning modes and i didnt spend much time in them (without hte manual, i didnt know!) Boost holds decently atm, but its a bit jumpy up top. I'll think i'll do another setup and see if it will hold boost better.
One last question, regarding the learning mode, what boost level does is it supposed to reach during setup? Like stock wasteage levels? or something preset on the unit?
You get into learn mode by holding power and over take boost down for about 6 seconds or so, it will then come up with -
P1 - learns the stock boost curve, do as many runs as possible, 2nd, 3rd and even 4th if you have a nice big long non-cop patrolled road :) Do as many as you can
Press the power button, it will then go into P2 mode. Press the power button again when you are ready to go, and it will start.
This mode is measures pressure drop between turbo and inlet, one full boost (try to start from around 2500rpm until rev-cut) is alll that is needed, if it is sucessful, it will come up with a digital boost gauge, if it doesn't P2 will still be displayed. Keep doing it until it works :D
Good luck
P.S - dAVE, I think I have emailed the manual to you before as well??
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
