RBish Posted October 27, 2011 Share Posted October 27, 2011 how much a/c gas does a 89 r32 gts4 air conditioning system hold. think i need to do the 2k resistor in the outside thermistor plug too cos its always blowing hot. i tried the search a few times but no luck thanks Link to comment https://www.sau.com.au/forums/topic/381396-ac-gas/ Share on other sites More sharing options...
Moodles2 Posted October 28, 2011 Share Posted October 28, 2011 R32 common problem is with the servo actuator motor near passenger kick panel, the cold solder goes in the pins inside the plug causing it to not receive power unless the plug is physically pushed in. Wherever the last position the motor had power determines whether you are stuck with hot or cold air, Search for the R32 service manual, it has the method on how to put the climate control into diagnostic mode so you know exactly what isn't working. Have a read of this thread: http://www.skylinesaustralia.com/forums/topic/236745-r32-airconditioning-not-working/page__view__findpost__p__4143375 Link to comment https://www.sau.com.au/forums/topic/381396-ac-gas/#findComment-6083189 Share on other sites More sharing options...
RBish Posted November 6, 2011 Author Share Posted November 6, 2011 anyway here is what i got from the diagnosis mode can anyone help? -26 = blend door fault. and my sensors 22.5 = outsidetemp 22.5 = inside 32 = air intake (before evaporator) -30 = refrigerant temp (after evaporator) checked the blend door and it wasnt moving with temperature settings so i unplugged it and cleaned the plug and refitted it and now the blend door actuator is working. so i think i just need a/c gas. Link to comment https://www.sau.com.au/forums/topic/381396-ac-gas/#findComment-6097511 Share on other sites More sharing options...
