I wouldn't say it was too rich. It's on the safer side (11.5:1), but I wouldn't say it's too rich. The power gains made by pulling 0.5 out of it to bring it too 12:1 wouldn't be worth it.
If you think your lacking power, then maybe have a close look at the ignition map.
J
Can you gurus have a look at the attached dyno chart and give any comments on the AFR i.e. is it too rich ?
Hi Jezzrr, let me start off by saying Steve knows his stuff, so the first thing I would do is ask him about the AFR's.
So to answer your question, for cars that we tune I would be aiming for slightly leaner ratios. I very rarely aim for less than 12 to 1 and I notice yours gets under 11.5 from 6,000 rpm onwards. Safety is an issue and there may be a valid reason why it is tuned that rich. It also may be a matter of tuning limitations, sensor out of resolution etc
Bottom line, ask Steve.
Sydney Kid,
Cheers for the reply, you rarely aim for less than 12 to 1, what do you aim for exactly 12/12.5/13 to 1 ?
Jeremy
Sydney Kid,
Jeremy
Hi Jeremy, a bit of philosophy first, otherwise my response might not make much sense. I use A/F ratios for safety not ignition timing, this is because I like to keep the response as fast as I can. Others may prefer to use ignition timing as the safety and sacrifice a bit a response so they can run higher A/F ratios.
Having said that, for a race car, I aim for 12.5, but it really depends on how close the detonation is. Some engines handle 12.5 easily, no knock at all, others are in the 30 to 40 range all the time. It is to do with the preparation of the engine, particularly combustion chamber size, shape and polish, with squish also being important. There is also the question of fuel, we can run 13 with Turbo Max but Optimax doesn't show as much gain up there. LMS is in between.
Plus we use a lambda sensor for each cylinder when tuning, this gives us a reliable A/F ratio for each cylinder. If you use a single lambda sensor then you get an average of all 6 cylinders, and some may be richer and some leaner than the average. Obviously all of the race cars have a lambda sensor fitting welded in each primary exhaust pipe.
For a road car, around 12 to 1 is my target, but again it very much depends on how close the detonation is. I check the individual A/F ratios with a pyrometer, but this is not as accurate as using lambda sensors. So on some cars you end up with an average of 11.5 as the best you can achieve. Often we find that the rear cylinders are lean and the front rich, so you have to tune to the leanest cylinder.
So it's not so straight forward, that's why I suggested you check with Steve, I am confident he will have sound reasoning.
The difficulty in Perth is that we dont get Optimax we can only get BP Ultimate 98 so that may explain why its run a little richer ?
That's OK, in Sydney we get Optimax sold as Ultimate.
To give you a different perspective again, I was told by a D1 Driver that they tune 11:1, and use timing to get good response.  This is how they tune their (Signal and Tinker drift club at least - that's who he drove for) cars.
I can understand that, for drifting, they need ultimate throttle response. Plus drift is very harsh on the engine, free spinning wheels, high rpm for long periods, rev limiter incursions, low airflow for radiator and oil cooler etc etc. They can't afford to be blowing engines all the time, so a bit of safety is essential. By "afford" I mean a blown engine in competition means you loose, plus the cost of fixing it, of course. You also need to remember that, in drifting, a few horsepower either way is not going to make any difference to the result, but poor throttle response sure is.
This is quite different to a drag car where every horsepower counts. It is not so different to circuit racing where throttle response is very import, but you can't afford to give away a horsepower advantage to the opposition either. You need to tune it for the intended purpose, that's why I always ask "and what are you going to use the car for?"
Horses for courses as they say.
Hi Boostd, we have had a change of control fuel in Production Car Racing this year to BP Ultimate. Previously the control fuel was the same batch of Shell Optimax used by the V8Dinosaurs. I have asked a number of times for access to Ultimate direct from BP and have been told that only WA and SA have Ultimate sourced from Kwinana and it is not economical to ship it from Perth to Sydney. So the Ultimate sold here is actually sourced from a "local refinery". Since only the Shell refinery has 98 capability "locally" then all the Ultimate sold in Sydney must be Shell.
I can tell you that the Shell refinery is very old technology and the batches can be quite different. Hence the reason why they made one batch and used that same batch for the whole season of dinosaur racing. This has been happening for a number of seasons now and they stick it in a tanker and send it to the races all over the country. It even goes to NZ for the race there. If (as a registered team) you want to do engine tuning or practise then you have to go direct to Shell and get a drum from this batch.
Maybe you have been a victim of the "different batches" problem.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
