Hi
Im looking for an ac condenser in nsw to suit an r33 gtst
Contact Keith
0403 548 222
Cheers
gday there bud , how are ya
yeh sure can help you out , have 1 in stock ready to go man , can do it for = $150 each great condition hey
let me know if your interested so we can sort it out for you asap
cheers anthony
Is this here what you're after?
This one's just been removed from a JustJap R34 GTT front cut with 113000kms.
$120 pick up from Wollongong if its suitable anf youre interested.
PM Reply
Cheers
Nathan
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
