Hi guys, i have a new Ogura ORC 709series twin plate clutch for 6speed 2jz supra's. It was only mounted to my engine as a display and removed. It's BRAND NEW and in UN-USED condition. Good for any applications up to 800hp. I've left the clutch down at my mechanics so if your local u can pop down to Powertune Australia to view/pay/pickup during working hours.
Contact Details : Anthony - 0410 372 671
ITEM NAME: Ogura ORC 709
ITEM DESCRIPTION: Twin Plate
ITEM LOCATION: Fairfield East NSW
ITEM PRICE: $1500 inc shipping aus wide
ITEM PICTURES:
Good clutch, I use this for 3 years without any issus. Does she include the Push to Pull converter lad??
She doesnt include the conversion kit but i can supply it for $480
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
