Greddy Profec b spec 2
second hand but works perfectly. Comes with everything you need. holds stable boost without an issue. only selling due to upgrading ECU which has boost control function.
pic so you know which type
Price $300 posted.
Neo R34 Nistune ECU
Ecu is plug and play in any manual R34 or stagea with neo motor. has nistune board on it ready to go. Also has tune for e85, cams, 3076, injectors, z32 but thats useless to most people. your buying the ecu here pretty much.
Price: $600 posted
R32 GTR Radiator + Shroud
near new R32 GTR radiator from Koyo (only 3 months old) inside of core is as new condition, outside is a little muddy and dirty but will clean up no worries. With shroud which is not cracked.
Price: $300
RB clutch fan and Hub
RB30e hub (shortest of all RB hubs) and R34 neo fan, useful for running clutch fan in your RB powered S chassis
Price: $120 posted
Intercooler
300x450x76mm with 2.5inch in and outlets. ideal for mounting in tight spots. 6 months old and inside of core is spotless and oil free. minimal bent fins
Price $100
Z32 AFM with plug and Neo plenum pipe
pipe is made to relocate the AFM on the cold side of the intercooler before the throttlebody. pipe also eliminates the over the radiator location. can be adapted to fit any neo enginebay. and probably any RB engine. AFM is 12 months old comes with plug and works perfectly.
Price: $400 posted
Located Adelaide SA. can post any item
contact details.
PM me or txt 0412 938 933
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
