Hey guys,
Ive got an r32 gtr that I was planning to do up for a bit of track work.
The car has 118,000 kms, the paint work isnt; crash hot and the interior is typical for an r32 though for the price I think is acceptable.
The body is straight and paint needs some loving,
The interior is all there though suffers from typical R32 drama's (bubbles in dash, fading on rear headrests, dash vent cracked)
The car is very original and comes with stock floor mats, complete and untouched boot layout, and under hood cover.
93 model GTR so comes factory with the r33 crank
Its got;
Vipec V44 plug in ecu
Tomei adjustable cam gears,
Tomei type APoncams
Trust Profec B EBC
Splitfire coils
HKS GT-SS twin turbos
Kaminali turbine outlets
3 inch catback exhaust
Sard FPR
Sard in tank fuel pump
Sard injectors
Nismo front and rear sway bars,
Slotted front rotors, aftermarket brake pads.
There are no leaks and the thing starts and runs perfect!
Currently makes 280awkw on 17 psi through stock air box and stock panel filter (no K and N)
I am after 8.5K for it
0419 743 272 Dan
feel like going all boost cruising here, swap for a 94 GTS T?
kidding, nice car tho, wish you did this like 6 months ago, i would have snapped this up in seconds
Ha I even had a look in your topics to see what it looked like,
Im collecting too many skylines atm, one has to go.
Will sell rb26 + HKS GTSS + gearbox + injectors/loom ecu for 5.5K if interested
In all seriousnesd would you look at a trade. I would love that car but cash poor. Mines a 95r33 coupe.
would it be able to get a rwc ok.
Cheerz
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150702294810
Hey guys,
have recently put up an ad on ebay for this bad boy together with alot more pictures
mate, if you wanted to have a look at what i have, all you would need to do is ask, i would so love to have a R32 GT-R
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
