Hey guys not selling but i want to buy!
ok
used eboost2
or any electronic boost controller
used r32 HDI intercooler
used aftermarket r32 radiator.
used aftermarket r32 ecu thats reprogrmmable.
used twin plate rb clutch.
used high mount t4 exhaust manifold with external gate..
if anyone has these items please pm me with price and stuff cause i kinda need em but i won't pay stupid arse prices for them.
https://www.sau.com.au/forums/topic/383572-hahaaa-tricked-ya/
  • 1 month later...
Got a profec b spec 2 with a Drift brand Electronic Stepper Motor Boost Gauge PSI reading, white with red needle illumination.
Selling due to upgrade.
290 posted and it's yours.
hey mate ive got a greddy pro fec b spec 2 for sale for $250
an ARC turn flow FMIC for r32 for sale for $700
and a R32 stock ECU with a nistune board installed with a Chasers tune (HKS2535, GTR injectors, Z32 AFM, Bosch 040 fuel pump which made 230kw)
Let me know if you are interested in any of the parts 0431 222 796
Cheers
have an r32 nistune ecu thanks guys bought today, what power level will gtr cooler handle??? looking at around 300rwkw with rb30, still chasin other items though peolpes!!! please send me pics of both coolers, don't want to buy a really bashed up one, not keen on arc one as i can get a hdi one new for less but i will have a look none the less.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
